so what yall think i have 2 of each rim 15x 10 8 lug kinda crappy and 2 15x12 8 lug rims that are basically new and the tires are 15" wide. which ones would you use
sell or throw out the whole lot and get some good tires and matching rims. Should be able to get used tires on rims for $200 if you keep your eyes open
i already have the tires. i guess i could sell them but they are growing on me
What'd this going on? If it's on a jeep on large axles I'd go with the 10s or narrower for trail riding. For mostly mud go with the 12's to get a little larger footprint from the tires.
the narrower the better for keeping the tire on the rim at low pressures.
its for my cj7 the rear is a 14 bolt and the front is a chevy 44 wb@ 100" and used on trails mostly with some rocks and mud
go w/ the 10's for reasons stated above....
My bad. For some reason I was thinking you had 2 tires tooQuote:
Originally Posted by colman
they can be put on 15x8 wheels, i had a couple on a set once.
actually i have 5 but the spare already is on a 8 lug rim i just need to figure out what to do for the other 4, i think i'm leaning toward the 10's
I went with 16x10's for my 38x15.50x16 SSR's and like them.
where is the ur gay option for speaking of running a 12 in wide wheel?
oh come on frick. 15x12's are the bomb diggity.
well i have 2 new ones i got in a trade so it was more of what i had verses what i should do
these are your tires on 15x10's though. i like em a lot. hard compound rubber. they'd be better grooved, but i'm low schooled. for dirctionals, you can turn them around when you rock crawling... though i never do... go rock crawling.
i just went and looked at the tires they are actually gumbo monster mudders, i think they are made by who ever make ground hawg. not really sure tho. thanks for the picture
