I'm getting alot of static still. I think i need to get a stainless mount so it is more grounded. I can hear my alternator through the radio too. I still don't know if it works because no one around here has a cb
matt andrews has one, i think all mine are broke. his sig is neilthedestroyer
where is your power to? did you go to the fuse box or strait to the battery?
I don't know. It also works the cig lighter
Go straight to the battery. Your ground to the frame may still not be good enough on the antenna also.
If you give me back my CB, I'll put it in my truck and let you test it all out.
I really just want it for the P.A. :blackflipoff:
i highly doubt its an antenna grounding issue. go strait to the batt as ed said.
That's possibly the ****tiest place you could mount an antennae. Try to move the mounting location up further so the coil is above the bed rails. Ideally you'd have it in the center of the metal roof.
If you want explanations on why, search "ground plane". You'll get alot of ham radio crap, but it applies as it's the same thing, just look for people talking about 10m or HF stuff. CB's are actually 11m.
go doug, i thought you were dead
If i mount it on my roof i can't fit in any parking garages. Most of them have like an inch of clearance above my roof anyway. I ground some of the galvanized stuff off my mount and i am getting even less static and alot more power on the meter when i press the button.
mr. watson would sh!t. dont breath the galvanized stuff.
not welding it, just scraping it on the concrete:gigem:
thats how i roll:flipoff2:
