vacuum leak
vacuum leak
vacuum leak.
edit: didn't see the last page.
Put back on the efi
carbs suck, run tbi. :)
Massive vacuum leak. Apparently ford used a different base on some of the 2bbls that won't fit on a normal 2bbl adapter.
Sooooo Lubelocker is the best thing since sliced bread..
Didn't know you needed that on a Barbie jeep
Yuppie......is rtv not good enough for you?
What's the odds this strap is worth a ****? $22 shipped 30'x4" with looped ends
http://www.amazon.com/Grip-Heavy-Dut...=pd_sim_auto_3
I ordered one
So I need a ram for hydro assist.
I know the norm is 8" stroke, but how do you match the speed of the ram with the speed of the steering box? If the ram is slower than the steering box will you be able to pull the ram out or push the ram in with the box as long as its moving in the same direction?
Looking at this
http://www.tractorsupply.com/hydraul...stroke-1831404
I like the ends on this because I won't have to buy heims. I'll just weld a piece of 1/2" plate with a hole on it onto the axle and the tie rod
Thats the Ram pops has on the big green gay 40. Works pretty good actually. After that I have never set up a Hydro system so no clue... good luck! :D
Just spend the extra $20 and get the psc RAM with hiems and tabs
I too suggest the psc ram. Think mine is 1.75
