I don't understand the residual valve, so I bet it's that!
You should post a pic of that adapter, it's ****ing sweet!
There are residual valves for discs. Supposedly it keeps a little pressure in the lines so that the calipers do no open completely and pull away from the rotor, requiring more pedal travel to get it back. Does it work, or do I need it? I don't know. I put in on in an attempt to find something to make my brakes work better before last weekends trip. It was discussed alot on pirate when brake problems arose, so I figured I would give it a shot to see if it helped.
As for places air could get trapped, most of the hardlines are still in the stock locations, and I have never had problems bleeding a toy before. I might try reverse bleeding it, but how do I do this?
but the brake problems existed before the residual valve was added. Remember it was a quick fix I slapped on the weekend before the trip.
As for my adapter, here is an example of one
http://www.rockstomper.com/images/pr...es/mckit02.jpg
Mine doesn't look as nice (hell, I didn't even paint mine), but its pretty similar
