time for a colman low offer, 30 for the rims?
Updated
naw i'll pass, don't need them just want them
(2) 15X10 Steel American Racing AR767 wheels, black, 5x5.5-$40
(5) 35x12.5x15 Procomp X-terrains. 50% tread, spare has a hole in the sidewall (has boot, does hold air) will get actual measurments-$400
(3) 255x70x16 Goodyear Wranglers. 25% tread left, some cracks, hold air and were driven on until today. Make good rollers or cheap work tires/spares-$10 each
YJ Power Brake Master Cylinder with fittings to attach CJ brake lines, bolt it up to a cj or yj. -$20
It's a tube, not a boot.
Someone is confrontational today!
No, it's a boot. I've seen it dismounted. It looks like a 4x4" patch however it is semi-inflated and is adhered to the sidewall. Bikers use boots all the time to fix trail flat, I haven't seen them to much in the offroading world though.
interesting. no confrontation. just observational.
all right, everything is $10 each. come and get it
13" "zenon" television. works just fine
16" electric fan, brand unknown, works fine-sold to frick
one of those self coiling air hoses, yellow, i think its 40'
(3) 255x70x16 Goodyear Wranglers. 25% tread left, some cracks, hold air Make good rollers or cheap work tires/spares
(2) cj stock proportioning valves
cj7 drivers side side view mirror, faded
braided stainless brake line, 24" long with banjo fitting at one end and standard 3/16" female on the other
will post up more as i come across it
ill take the fan, i will be in c.s this weekend and can pick it up. This is an electric fan for a truck not your house right?
this is the wrong thread but i run a 95 yj booster and master cylinder.... seems to stop my 42s
4 wheel disks. no proportioning valves
coop, i think you are right for the most part. I think the proportioning valve was the main problem. we'll see how it all turns out.
