Originally posted by Fredo
yeah, because timing obviously isn't that important...it's all about that idle mixture! :rolleyes:
Also, if you're saying you pulled the outer ring off the balancer, as in the metal on the outside of the rubber isolater between it and the inner hub, you have successfully destroyed that balancer and It should be replaced. Unless you just like the idea of spinning a main bearing or throwing a rod.
i got the fix for that. Just cut the same weight off the flywheel in just the right spot and it will balance it right out.
