should I get some 37's for the rover?
Or maybe some 38's
Or add some coil-overs
another shot
up close
whats up with the dual brake lines on that last pic?
and is that an air tank or part of a turbo setup on the coilover guy's truck? seems like he could have done that better with less holes in the hood
or how about you build a console, and fix the idle problem....
what a homo:flipoff2:
holes in the hood for coilovers are the shiznit
http://www.sn-fab.com/projects/Brett/roundy088.JPG
http://www.sn-fab.com/projects/Brett/roundy089.JPG
http://www.sn-fab.com/projects/Brett/roundy091.JPG
coilovers AND 37"s :cheers:
on both...I didn't even look that closely at the tires on the one Grayson postedQuote:
damn....i didnt think rovers could actually look that good...:flipoff2:
those look damn good man...i think you should go 37's
Don't Range Rovers have 4 piston calipers up front? Maybe that's just the required lines for each side of the caliper?Quote:
the front calipers are on two circuits. so if you loose one line you still have brakes in the front. RR's have 4 piston caliper fronts, two piston caliper rears, e-brake is a drum on the rear drive shaft.
do they make General's in a 37 or 38?:flipoff2:Quote:
Originally posted by Graystroke
Or maybe some 38's
