replacing lower bearing on cj steering column
what is needed to replace the lower bearing on the cj tilt manual steering column, by looking at the diagrams it looks like\
1.detach steering shaft
2.remove snap ring from column
3. remove plastic retainer
4. remove bearing
5. replace in opposite order.
is that it, just double checking myself so i don't have anymore surprises on this cj.
edit: its really a 80's gm column, but i wasn't thinking and bought the bearing kit for jeep, this WILL work though. . . right?
