Come to find out, FJ 40 u-joint flanges dont match PU flanges. Need a set of pu driveshafts that i can build off of.
Is it the bolt diameter or the mating surface that doesnt match?
2 will match but the other 2 are a half hole off. bolt diameter is the same. Isn there like 3 different bolt patterns on toyota drive flanges?
Yes, there are several patterns. Several companies make a flange that accepts all 3. I might have a front shaft in the garage you can have for cheap if you need it.
why don't you just redrill the holes
x2
Because then he's have slotted holes on 2 of the 4 connections and only 2 bolts would be in shear instead of 4. Those flanges and stock driveshafts are cheap.
Rowdy - no driveshaft, I must have given it away.
what he is saying is that rotate the shaft and drill 4 new holes. marlin crawler has the 3 pattern flanges for 25 bucks. we will see what i can do first
hello, mcfly...
just make 4 new holes.
:doh: rowdy beat me to it.
why are you using cruiser shafts anyways?
cause they came with the rig and im poor
