Cant see your pics, maybe bc im not on tapatalk?
Bronco when travis bought it and now
http://i61.photobucket.com/albums/h7...s/IMG_1269.jpg
Super cute picture in front of the Bronco Buster trail sign at Hidden Falls
http://i61.photobucket.com/albums/h7...126_160416.jpg
Side exit exhaust
http://i61.photobucket.com/albums/h7...126_160252.jpg
Hopefully you don't sell out like Tummy...
Talk to me about parking brakes. Right now I have a 9 inch in the back with a disk brake swap using el dorado calipers, but my problem is that I don't have the parking brake cable brackets so they don't do anything over what a chevy truck front caliper does. I can get the brackets but I have to buy new calipers to get them and everything I've read says they aren't worth it. I need something that's 5x5.5 and disk, I don't know what everyone is using that works well. I'm not opposed to a driveline brake or swapping out my rear disk setup to a different one but I want it to work well.
I say go for the driveline break. The elderado parking brake was crap.
Jones has a pretty sweet setup, its a master cylinder up on the parking brake. You plumb your rear brake line thru it, under normal operation your rear brake line goes in it and it just passes fluid thru. When you depress the pedal on the e-brake it holds then uses the extra master cylinder.
What about using a line lock?
Not sure what Tommy is going for, but a line lock won't pass a state inspection, The Jones fake parking brake system will as long as the guy doesn't look too close.
With some quick googling it looks like all I need is a remote reservoir master cylinder, some fittings, and make a bracket, seems easy enough. Does Jones have any complaints about it bleeding down? I'm sure it would take a while for it to happen but I saw someone mention that when I was googling.
No line lock. I've heard too many complaints about them not working right when you leave them on. I also don't want anything electric in my parking brake.
There's also the option of just doing a shutoff valve but then I'd have to route brake lines inside and it also wouldn't pass inspection.
I've been planning to add a shut off valve on mine, but if you're trying to pass inspection, I don't think that would work either. I think a "real" parking brake must be all mechanical.
What are you trying to accomplish? Pass inspection, have an operational parking brake, or both?
That being said, last time my jeep was inspected, they didn't catch on that parking brake didn't do anything (it wasn't hooked to anything). They just pushed the pedal, then released it....
Both, my bronco is a stick at least for now so I'd like a better way than turning it off and leaving it in gear for the trail. There were a few times in clayton I didn't trust leaving in gear so I just stayed in the bronco instead of helping spot or watching. By law, it doesn't matter if it's mechanical or hydraulic, it just had to be separate from the rear caliper or wheel cylinder that's used under normal braking. The piggyback master cylinder isn't technically legal but would pass and not be noticed if hooked up right.
The Jegs brand electric line lock I had on Pigpen would get hot as **** when left engaged for extended periods and started to get stuck in the closed position after a year or so. I'd have to get out and whack it with a stick to get it to disengage. They're only meant for intermittent use. I'm pretty sure hydraulic brakes are not allowed at all for e-brakes.
http://images.tapatalk-cdn.com/16/02...1406b82105.jpg
Doesn't say what it can or can't be, just that if any one part breaks, you can't lose both systems. There's some medium duty trucks with hydraulic parking brakes.
It does say leakage is not allowed and I think they are meaning hydraulic leakage. All the big boy trucks I have seen have air brakes and the e-brake dumps the air, but I'm no diese***ogist.
