can someone tell me the distance from center pin-center pin on a YJ in the rear? i am goin to get the axle ready before we pull the old one out and wanted to make sure the perches were correct
how are you setting the pinion angle without the axle under the jeep?
its sprung under and already has the shims in it, so i'm assuming that i'll be close enough, if not, then i'll have to redo it, i was just goin to check the centering pin holes for now
