Originally Posted by uglyota
I really wish I had a flat deck (no rails). Very limited in what work I can do on the rig with it on the trailer (can't remove a wheel).
What I've heard is that channel construction is better than angle. You might not be able to find one without rails that is made with angle. Mine is angle and I have never seen or felt it flex.
Wish I could fit truck tires (245 or 265) on mine. All that mine will fit are like 205 car tires, and I would rather be using used cheap truck tires than car tires (heavier duty).
Finally, I would rather have a longer trailer than 16' for hauling whole joints of tubing, bigger rig if you need to, rig+jobox, etc. Maybe 20'?
