Originally Posted by 85cj7
ok so same problem different thread, the bracket that holds my alternator and tension belt pully is broken, in one of the holes that holds the alternator is a broken bolt, so i guess i could drill it out, the other arm that holds the alternator is broken off, can you weld this stuff, its cast aluminum? Went to two salavage yards today on highway 21 and neither had the bracket i found out that its surprisingly specific its for a 1990 ford 302 with a serpentine belt system, no clutch fan, and no a.c. i pulled a bracket for the alternator from a 302 with a.c and a clutch fan just to make sure but no go. So does anyone have any ideas, i've got to get this fixed fast
