Originally Posted by BIGJIMMY
I plan on mounting the hardware first, then welding them on when I get around to doing the 14b in the barn. As for rims, thought of going H1's?
are they 15 in? cuz i got 15 in tires and dont think i can swap them out for 16s, plus i heard that 16s dont hold a bead very well. where do you get them at?
H1 rims are 16.5" diameter and are a double beadlock wheel, so you don't have to worry about ever losing a bead. You can find them all over, mostly people get them military surplus and then resell them.
the biggest problem with the h1's is the backspacing.
which can be fixed rather easily w/ a torch, welder and recenters from usa6x6. :gigem:
and a grinder if you want it to look good.
Paul, a membership on www.coloradok5.com would be a good investment for you. More info on blazers than you'll ever need.
Originally Posted by agjohn02
ballistic fab caliper brackets are 30 bucks for the set
$40 shipped. ruffstuff's are thicker and better looking (i.e.- plain).
only if your cuts look like you did them w/ a titanium toothed beaver. :flipoff2:Quote:
i just think a machined looking edge looks better than the best torch cut. i grind plasma cut edges. im a freak like that.
you need to lay off all that meth you picked up in Clayton, then maybe your hands wouldn't shake so much. :flipoff3:
I am not tryin to say I could do any better at this point and time, but with some torch time I can get it pretty close to a machined edge. (Atleast I hope I can again.)
let me rephrase... i grind CNC plasma cut edges...
can you spell OCD???
paul just go get a pair of some 15 in 8 lug wheels from sunnit or discount, that match your wheels. Will his 15's hit anything with the disk swap?
