hey I found a axle, but I need calipers for it. Its a 1980 front axle, and if anyone knows where I can find em let me know. thanks
I think I have a set of the IFS calipers if those would work?
and I may have some SA calipers, but I would have to check when I go home on the 6th
Originally Posted by J Cooper
yes, call and see what the core charge is. if its not too much dont bother with trying to find old ones. you're not planning on bolting up used calipers anyways are you?
buy calipers from a parts strore. I'm sure someone has some old calipers you can use as a core. you can use any calipers, or a brick of the appropriate weight for a core
Originally Posted by JBrown89
ive got a pair of jeep dana 30 calipers in the back of my truck you can use
there $52. ea + a 30.00 core per side, so If someone does have some onl ones, That would be much appriciated. thanks
