used truck under $1000
I am looking for a new frame and body to replace the Bronco's rusted body. I am looking for something that is not a full size, has a good body onit, does not need a transmission or engine, 2wd or 4wd. All for under $1000. Has anyone seen something like this around town for sale.
Also, looking for a 1988 or newer F350 with a gas engine. Truck can be 2wd or 4wd, and wrecked. All I want is the wiring harness, computer and engine. Do not want to spend alot on this either.
Per this post I think your signature should properly read:
"Locked D60
Locked D70
42" Swampers
...need something to put them on"
:p
why not just build it out of square tubing? would be more fun and probably stronger. I am sure you are goning to modify it, so why not cut the body mounts off of your frame and do it that way?
