I really don't think warping would be an issue. I could be wrong. I have heard about dimensions changing during the heat treating process. As a rule of thumb I think you can plan on "growing" the OD by 1% when something is quenched.
my mistake. can we call it the kludge-v ?
:laughing:
I have told Krebs before I am interested in doing this but with a NP242 and Chevy 205. I have a couple of Np242's out of military HMMWVs at my shop and while the cases are significantly different than a normal chevy 241, I'm prety sure they use the same planetaries and shifting mechanism. The 242's are full time but that shouldnt matter for a dubler. I told Krebs he can have one of the 242's if we can make this work. The biggest issue with this setup that I can think of is the inner shift rail that Karl mentioned. On one buildup I saw, the guy put a freeze plug in the normal shift rail hole and extended the rail out the back of the case.
the problem some people have had is breaking the stub shaft between the two cases. I believe that this is more of an issue of the guys that have done spooky welding of the two shafts pieces or left it in stock form. You got a long wheelbase just slide the two together, and run a pillow block front d-shaft.
Just watch the classifieds and pick up a STAK or Atlas. They come up for around a grand, except for the bolt in jeep one. Bolt it up and sell all your other cases. Then use the extra time you have to swap the d60 in the front of the Klogger, or work on the Chevelle.
Any of you guys ever heard of this guy?
http://www.performancecryogenics.com/pricing.html
Claims he will cut, respline, and heat treat a shaft for $200.
IIRC, that is the guy alot of the pbb'ers go to. He used to offer the 'cage' for the H1's that you welded together yourself (to use in place of the pvc insert).
so I just looked at this thread...
there is only like one company that heat treats after machining and only one that rolls the splines. If you read the "sales pitch" on Moser or some of the other custom axle guys, cut threads sound just fine.
Actually - all new shafts from Moser and Currie (amung others) are cut after heat treating.
I think the issue is that when you respline one of these shafts you cut over 0.050 off the diameter. From waht I have read the heat treating results in a surface hardness that is only about .015 thick, so in effect you would cut away much of the surface hardness.
On a different thought, if you think of how the gear reduction works (and I am probably stating the obvious here), the shaft in the rear axle sees much more torque, but less rpm's than the one in the T-case. So if it would hold up in an axle, I think it would hold up in a t-case. I suspect most people's failure with welding and press fit gayness in transfer cases is the result of the higher number cycles that cause fatigue rather than one shock load.
