Front axle out of an 87 Chevy 3/4ton. It is 8 lug, has balljoints, and is complete. Anyone know what this axle is worth?
ill buy the 8 lug stuff off of it or the the whole axle $100
gotta pic? could be several types...i need one too.$101 :flipoff2:
I dont have it. I found one in a junkyard today. It is the one on 26th in Bryan. Guy said $250 for whole thing.
nevermind
It aint worth buying for 250 to resell. If all the parts are good and you want one to use, it's not too bad. Its 10 bolt. If you're in the market for one, Krebs may soon be swapping his out. It's got a limited slip and probably lifetime warranty on lots of parts. But Krebs has been wanting to swap it out since way back when before jeep got fullwidths, so I wouldn't count on it actually happening.
Or, I'll sell you a d44 of the 3/4 ton chevy variety with the flat tops and a high steer arm and lifetime warranty on lots of stuff and 4.10 gears and some sort of locking device for $350. Many people will think its a 60.
I just need all the 8 lug outer stuff-knuckles, spindles, stubs, bearings etc to make my furd 44 8 lug.
[QUOTE=eight] If you're in the market for one, Krebs may soon be swapping his out. It's got a limited slip and probably lifetime warranty on lots of parts. But Krebs has been wanting to swap it out since way back when before jeep got fullwidths, so I wouldn't count on it actually happening.QUOTE]
Thats a lie! I only wanted to swap it in before that spring break trip and didn't have the time or money then. After that it was supposed to go on the buggy, which it eventually will. It's only finding a temporary home under the blazer. And yes it will happen, sooner than you think once parts start arriving.
here
10 bolt
it looked alot bigger when i took the picture. So they made 8 lug 10 bolts?
Is that at Gordons? There's a burban there with a 10 bolt 14 bolt SF combo but they want $600 for the whole shebang. I really need a set of 3/4 tons to put in the burban so I can sell it.
hmm, i know where a set is...
Ya the outers is what i need too. The limited slip would be nice in the front, mines already got 4.10's so i think that findin just the outers would be cheaper than $350 for the whole thing and then just scrapping it or mine.
