TJ axles and parts
I don't have a clue on the prices so PM me and we can work something out.
All parts out of a 200 TJ with about 80,000 miles
TJ rear axle
Dana 44
4.56 Genuine Gear set professionally installed
Full Detriot
Alloy USA chromo shafts
Tera Disk Brakes
upgraded to 1310 u-bolt style pinion yoke
some sort of heavy ass diffcover Rockcrusher or something like that
Has fresh wheel bearings
TJ Front Axle
Dana 30
Aussie locker
Hydro Assist (ram included 1.75x8 )
HD One-ton steering (1.5x.385 wall tubing)
I have 2 extra unit bearing and a few extra shafts that could go with it.
I an entire spare housing, however it is bent so only good for bearing/brakes
one Chromo stub shaft.
I went through the axle in March and all of the bearing and gears looked in good shape
Rubicon Express suspension
3.5" superflex lift
all control arms have flex joints on one end and bushing on the other
all control arms upper and lower are ajustable so that proper steering angles are maintained
Adjustable trackbars front and rear, HD rear track bar
Bad: it needs new bushings on all of the control arms. Rubicon express sell them for $13 each
Yellow half doors with black soft uppers. Door are in great shape rarely used. $500
M.O.R.E Bolt in sport cage. Bolts to the floor through the drain plugs and the factory B pillar. You don't have to cut the dash and it adds alot of extra protection. $125
PM if you have any questions or want pictures.
Will anything from that lift work on an XJ?
all of the front suspension parts should work
would you happen to have an extra hub for that dana 30?
Ill take the hydro ram and a track bar
Yes I have an extra hub, how does $30 sound
All Parts now for sale individually.
Detroit $300
Chromoly Axle Shafts $175
Disc Brake conversion $175
4.56 ring and Pinion $125
Bare Dana 44 housing with TJ axle brackets $175
Prices Negotiable
So the 44 is parted out?
Do you still have the trac bars? *very interested*
and finally... Looking up info on the cage!
yeah, im interested... See what he has to say...
No word on the 44, I am talking to someone but have not heard anything definet
I have the cage PM me about it
Trackbars go with the rest of the suspension lift
do you still have the lift
