'78 Furd D44 Alignment
I repaired my front end ball joints, seals, bearings, etc. Before the repair, everything was wearing ok, except the front left was wobbling a little. The ball joint was a little loose on the bottom, so I replaced everything while I was in there. Put everything back together and the top of both tires seem to poke out a little. Do the stock cam adjusting sleeves have an offset from the factory? Cause I installed the new cam adjusting sleeves that came with the Moog ball joints. Any advice? Maybe put the original cam adjusting sleeves back in?
