the donor and case
http://www.flemcodesign.com/pics/zf/zf001.jpg
The leftovers
http://www.flemcodesign.com/pics/zf/zf003.jpg
the donor and case
The leftovers
Looks like it works on the same FM band as a TH400.
Probably
I take it apart, and put the pieces back in the same place as the pictures, and if there are leftover parts I repeat
Flem I have no idea wtf you typed about those parts. That's no small accomplishment. I have rebuilt a transmission made by zf, granted it was manual and Jb weld was used. But still Well done.
Even more impressive if the vehicle runs again.
Here's where it's at now. The truck basically came from barnwell before it was parted so I still have to clean all the crap off the pump
http://www.flemcodesign.com/pics/zf/IMG_1066.JPG
Automatic transmissions are filled with black magic and voodoo.... good luck
Looking good man! I wish ZF made a transmission that would work behind a 5.3. That thing looks way beefier than the inside of a 4L60e.
havent given up on the ac bracket yet. If its going to fit, its only going to fit 1 way
started throwing together a breadboard of sorts to move things around and check for clearances. if i can find a way then ill put a mockup together out of steel
http://www.flemcodesign.com/pics/IMG_1558.JPG
is that 3d printed mockup brackets?
yes, with lots of extra holes with hexagons cut out in the back for nuts
Ryan, I don't know if you heard, but Flem is High Tech. There is a scale model of a 22-RE head and valve cover on my desk to attest to his 3d printing skillz.
That is freaking cool. All of it.
Nice!
So where are the three ball truck nuts??
maybe youll just have to wait 6 more months
