Originally Posted by
Fredo
Found this....doesn't sound like a horrible task...
Your temperature control actuator is bad. It's a little motor that moves the temp door. They are about $70 at the dealer. To change it you need to remove the knee trim panel on the passenger side (3 screws, 7mm socket). The actuator is in the center above the transmission hump. It has one harness plugged into it and 2 screws (5.5 mm). Take the screws out and it should drop straight down. Align the actuator with the lever on the door and put the screws in. Plug the harness back in. Turn your temp control to cold and remove the HVAC 1 fuse. Should be in the fuse panel on the drivers side of the dash. Turn your key to run and leave it on for at least 1 minute. Turn your key back off and put the fuse back in.
