A head start on "Last Minute"
I figure since I'm going to be rebuilding much of the FJ and I want it ready for TCC3 maybe I should start working on it now and not the first week of april.
To do:
Power steering (cure the "death wobble")
Replace stump hanging tranny crossmember
Move engine rearward to get weight more centered
Rebuild the chassis wiring harness so it looks and functions better
Maybe:
Build on-board air system
Maybe but prob not:
Build a better cage
Find a new topless hula girl for the dash
As of today I've got the stock steering removed (see my classified ad) and the radiator core support removed so it's not in the way of the steering shaft. I also have everything set out to install a serpentine belt setup from a 93 camaro, using everything except the air pump. Right now I plan on using the stock camaro A/C for onboard air if possible (maybe with an inline oiler on the intake of the compressor?) I plan on getting steering ujoints from work, but where can I get the 3/4" OD heavywall tubing that fits borgeson steering joints.....Mack Bolt and Steel?
