also picked up a fuel cell a while back since the old pump decided to take a crap on me at trees, still need to install that, going to run the inline ford fuel pump
removed the rear half of the carpet and the headliner
hooked up the in line fuel pump and some lines to the fuel cell, she fired up and i was able to drive around witht he front wheels
thinking about mounting the fuel cell crossways behind the rear seat like so, need to get some better fuel lines tho
every time i make progress it seems somthing else comes up,
i made some hard lines for the fuel cell
got the rear drive shaft lengthened and installed, once installed i noticed a crunching sound, decided to pull the diff cover to look see, couldnt get all the bolts off, but was able to see in there and all the welds are broken in there
so my list for clayton as of now
reweld rear axle
mount fuel cell and add supports
run vent line
rework steering
install new cb
So after making an extra air vent through the bottom of the motor and sitting for a year, the XJ finally went towards the bright light in the sky and there is no turning around for it. I am going to pull the good usable parts and scrap/sell the rest. Going to keep the tcase, tires, fuel cell and front axle. If anyone wants anything let me know.
My neighbor was selling a 94 YJ on 33's with a 4.0 and AX15 for the right price and this will be the new play toy.
i bet karl could use the rear springs
i'd like the steering shaft between the box and the column
what tires did you have on that thing?
