ford/chevy/jeep spindles
i need a set of spindles that are 6 bolt to convert my waggy front d44 from 6 lug to 5x5.5. i was told that 74-77 jeep d44 will work. i have a set of 79 rotors that can go with the deal if that helps as well as the spindles that i have that work with said rotors. any help anyone?
i also have seen that 77 and earlear ford spindles as well as chevy. anyone have any
Cheaper than what your wanting to do. prob bout 10 buck a rotor if that
You'd be better off turning the OD down on the spindle rather than drilling the hub and rotor. I think Matt Conley had his redrilled at Sunray, I don't know what he paid but I know it wasn't 10 bucks.
any one have a ford spindle that i could barrow to turn mine down so they match up?
yeah i've got one off of a 78 d44
can i barrow it, or if you have 2 what do you want for them
yeah i have 2 but i wanna keep the axle together
you can borrow it whenever as long as i get it back. just pm me for directions if you want
1 Attachment(s)
you do know that ford spindles are shorter and 5 bolt instead of 6, right? outside axle shafts won't work.
buy the correct bearing, measure the ID and have vilas turn the spindles down
1 Attachment(s)
i needed to barrow them to see if they are what i want and he ended up having some from a bronco that i got that look like they are gonna work. also got slotted drilled rotors to go with them. the spindles are 6 hole like the waggy not 5 fyi
the ford spindles are 1/4 inch longer. i'm going to assume that is a big deal. is it or can i make it work
