what are they off of?
i think I used ones off a 78 ish 3/4 ton chevy truck
The disk conversion I did on my d70 uses late 70's-early 80's chevy 3/4 ton calipers as well. No issue's with leaky fittings.
yep same thing on my 609 (78 k-20 calipers). Are you sure you have the proper banjo bolt? My front calipers are waggy and my rear are k20, look exactly the same but use different banjo bolts. The thread and pitch are the same but the diameter of the neck of the bolt with the hole is a different diameter from front my front to rear. I mixed them up one time and they leaked. Might want to check that just to be sure.
the 85 calipers did not have the ridges for the copper washers to seal against. i got 78 ones and they had them. i also got the right banjo bolts from napa.
i'm working on changing out the tres for heims right now. in true tamor fashion, i'll be doing the doubler at the very last minute...
tire joint did a good job. northwest fab doubler stuff is shiney.
vulcanized?
where did you get it fixed at?
Between the 'a' and the 't'... :flipoff2:
yes vulcanized, same place in houston as JB i believe
Nice.
