i think so. both should be 32 spline.
can i take the entire bottom end of a 2 stroke engine (minus jug, carb, etc) and leave it in a parts washer w/o any ill effects?
there is a huge accumulation of **** in there and i don't feel like splitting the case and cleaning it bit by bit.
if it's a ford 205 you can as both are 32 spline, 203 front flanges fit on them too.
Generally rubber does not like parts washer solvent. The crank has to be attached to something right? How else does it transmit power. So somewhere the crabnk exits the case and there has to be a seal. Are you working on a dirt bike? If so this would be behind the drive sprocket.
I need to drill two 7/8" holes through my 1" thick high steer arms. Easiest way to accomplish this using the least amount of bits?
Drill press, low speed, and lots of lube.
Working on some trick little lights for my Axial RC truck, and am trying to figure out how to control the voltage.
I have read where I can get a 9volt battery down to 4.5v w/ a couple of resistors setup like in this picture below. How would I do it coming from an 11.7v battery?
http://i47.photobucket.com/albums/f1.../9vbattery.jpg
I have done this many times and I think only once with good results. Seems the large bits usually like to jump around instead of just drilling straight down the pilot hole.
Here is my recommendation. Drill a pilot hole, 3/8" or so. Then get a unibit that goes to 7/8". Use this unibit, slowly, with lube, to get the 7/8" hole started. Then switch to a 7/8" bit and finish the hole.
The unibit will start a good hole and the 7/8" bit will follow it through. Otherwise, when just stepping up bit sizes, I find that the large bit doesn't like to just follow the pilot hole. It chatters and you end up with a larger hole than you wanted.
Yes.
Is there a difference in a dodge np231 and a jeep np231? If so what?
