I told you no clutch dumps until you got some new rear springs. Also I will be very disappointed if you can't fix a drive shaft in a week, I bet there is a plethora of ford drive shafts at dowling.
I have the parts I need except for the CV centering ball needle bearings to put that one back together. The h yoke and 2 u joints are all that are broken
This was from worn out CV parts, not pinion movement
Cup holders
Superduty front driveshaft in the back and 1350 yoke for the 9"
Fix AC
Front bumper
Fix the 1356 shifter plate so I don't have to guess where 4hi is
New radio that works
That's my list before alto.
C6 or E4OD?
With a C6 I get a longer rear driveshaft which means angles will be better and more possible travel.
With an E4OD I get OD and a lower first gear, but lose some rear drive shaft length and rear travel numbers. The wiring is also all there, although down the road this will be made more complicated by a mass air conversion.
Also working on cruiser status so OD would be nice in general.
C6. No electric bull****, cheaper.
Why would you go auto? If you do I'll take the zf.
If your planning on driving 70 mph, go with a overdrive.
All the electric bull**** is already there and ready to go. Also, a C6 on summit is 1300, and that's not far off from what I have found a reman e4od for.
A stick designed for towing or bigger light duty trucks doesn't do so well speed shifting. It does great with crawling and slow speed stuff but you really have to work it to go anywhere, you're never in the right gear for cruising and brodying at the same time. I ripped the shifter handle off at DSO, obviously whoever installed it didn't use enough JB weld. It's also a little on the worn side.
This thing could possibly be a DD in the very near future, so creature comforts are high on the to do list.
I disagree, leave the zf in, learn to drive stick. I had a Mazda m5od and it did not bother me, the zf is better than that.
What **** said
Leave the ZF in, Fix the A/C, that would be my priority if you are going to DD the thing. Oh and buy a half inch longer driveshaft or figure out why that thing is spitting them.
Zf
Auto!
