look at summit, jegs, or etrailer for the fittings you need,
I'd probably go with steel.
http://www.summitracing.com/parts/AER-FBM2517/
http://westtexasoffroad.homestead.co...rsteering.html
Any other tips on turning up the stock pump? Cook?
That's pretty much what I did. Works.
Did the same on my pump and it does work.
For the ram mount I used 1.5" chromo, ran it through the bender and welded it in. It's mounted in between the spring perch and housing.
i didnt do any mods to my pump, and it runs fine
the ram should not be too hard to mount
it just may not be completely where you would like it
I moded my pump I'm not sure it did much good. If you have the pump out I would do it, if not I would leave it stock. John did you see the 39.5 tsl's with rims on craigslist Houston?
if your looking for tires. . .
http://lsjc.org/board/showthread.php?t=37483
those r the fittings u need john
I got the fittings and a cooler yesterday. Summit's delivery is fast.
what size bore and what length stroke did you choose for your ram?
1.75 bore
8" stroke
.75" rod
