any more progress?
any more progress?
yeah the wiring harness is 95% complete and the tune is almost there, just need to do exhuast so I can take it all apart and rebuild the trans,
gonna go this route for 32 spline outputs and good assortment of ranges. 7ish:1 would be too low with the auto.
http://i54.photobucket.com/albums/g8...r2build061.jpg
so how is this thing coming along
its comming along, good got the exhaust tacked together and the fuel cell and radiator in place. another weekend of work and it will be ready to pull the motor to rebuild the trans.
I am going to stick with the d300 until i break it
you now have less than one month before shiloh, better hurry
mud still falls out when I beat on it with a hammer it is not going back there for a while
In with the Chevy power from BMF Motors
http://i46.photobucket.com/albums/f1...d/IMAG0010.jpg
http://i46.photobucket.com/albums/f1...d/IMG_2526.jpg
Radiator with trans/power steering coolers and Taurus fan which will be using a Volvo 2 speed fan relay controlled by the computer
http://i46.photobucket.com/albums/f1...d/IMG_2528.jpg
http://i46.photobucket.com/albums/f1...d/IMG_2529.jpg
How long will you driveshaft be with all of that stuffed in there?
30 inches or so in the rear, that setup is actually shorter than the previous setup, np205 is with 1/2 inch of a dana 300 in length
Got the motor in and started wiring/ plumbing
Motor barely clears the hood with the engine cover on
http://i46.photobucket.com/albums/f1...d/IMG_2570.jpg
Giant hole in the floor for the 205
http://i46.photobucket.com/albums/f1...d/IMG_2571.jpg
Headers, exhaust and motor mounts were a tight fit but everything fit on the passenger side
http://i46.photobucket.com/albums/f1...d/IMG_2573.jpg
Gonna be ready for alto?
I got all of the engine wiring and plumbing done (except radiator)
I need to wire up the fuel pump and gauges and the motor should be ready to start. Hopefully I can get it running either this weekend or next.
Let me know if you need help. Either way, let me know when you are going to fire it. I'd like to be there for that.
