if it fried the coil make sure that the wire for the tach has not grounded out anywhere that will fry a coil
trust me it has happened before this truck does not like distributors
Just took it on the South Holleman Nurburgring and its running good. It keeps throwing an intermittant MAP sensor error, something that would not have shown up on the old 160bps ecm. I think its because the MAP is placed on the throttle with the deadIAC. Maybe a small leak in the dead IAC valley that needs to be filled by a competant jb welder or something. Will look into that next week. It also starts a little rough. The ECM has tables for pulse width time vs coolant. Its not something that can be linearly adjusted based on old/new injector size due to open and close times. I think they need to be increased, but once it starts its fine.
Awesome I can't waii can't wait to see/hear it run greatt to see it sun great
Ok, I think I need to get started on the motor pretty quick. Tommy, what is the best time to call the boss man to visit with him a bit about it? I am going to see if I can't get it out of the truck sometime next week.
He is normally there from 7:30 am to 4 or 5. Talk to mark
Ok, thanks guys.
Crap, I am trying to locate a picture of my rear anti-wrap and for the life of me can't find one. Anybody have any constructive help they could offer?
http://i736.photobucket.com/albums/x...ieldIV/144.jpg
http://i736.photobucket.com/albums/x...ieldIV/143.jpg
http://i736.photobucket.com/albums/x...ieldIV/142.jpg
http://i736.photobucket.com/albums/x...ieldIV/141.jpg
http://i736.photobucket.com/albums/x...ieldIV/140.jpg
http://i736.photobucket.com/albums/x...ieldIV/139.jpg
Got most of the parts in today. We're still waiting on the cam, gaskets, timing set and a couple other small things.
That's a stroker kit with a cast steel crank, forged pistons and rods. Full floater pistons (notice the brass bushings in the rod). Comp Roller cam and springs.
Should be around 510 cu when we're done. Ed, we need the flywheel so that we can get the rotating assembly balanced.
http://i736.photobucket.com/albums/x...ieldIV/138.jpg
nice....
prety
No clarke has nothing to do with it.
