Needing a driveshaft. Sheared mine off yesterday.
:doh: front or rear? weld dat ***** back up so you atleast have a spare...
there are probably 20 different possible lengths of cj driveshaft.
I twisted the rear one in half and bent the splines
crawling a rock ledge and pop.
I see said the blind man...
You get that damn thing painted yet???
what type is it. is it flange mount or yoke style, about how long. 1310? ...
If the ears are still good, make a square tube one for a spare. I bet the coleman boys have somethin layin around...
its a yoke style. ill get a measurement later it has the t4 trans with the 300 case. not sure on the u joint type. Its a standard cj-7 ujoint . Ed, ill try to get some pics up when my camera gets back from the cleaners. Like i said before Ed, i twisted the splines on the slip shaft or i would have made a new one.
Is the slip shaft inbetween the yoke or is it a slip yoke in the back of the transmission???
If it is inbetween the two u-joints, find two pieces of square tubing that will slide inbetween eachother (like a reciever hitch) to the two yokes.
yea i realized that yesterday. going to go look this afternoon
if you want a relpacement look for a front driveshaft from a wagoneer or explorer 4x4 front shaft, yours and those should be 1310. then cut to length... or the square method works great for trail rigs. there are a lot of writeups on the internet on how to do it
With it being a rear shaft, I would only try to use the square for a spare because it will still see plenty of street time I am sure. It would do you good for a trip out to krocks though. If you get some extra lobes, make a spare for the front because it has a slight bend in it which I am sure you have seen when lookin past the shifter.
is it cv? i think i have my stock front driveshaft which is 1310
1976 F-100 Kustom Krawler
1976 F-150 Custom
1964 CJ5
