Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Thread: The Great West Texas Barn Rasing
    Dec 2005
    BFE, Tejas
    The step-dad decided it was time to build a shop here at the house. We are adding on to the existing garage by about 20ft. The final dementions are around 48'x40' with the open area with 15' celings. It will have 2 14'x'12 rolling doors and 2 regular steel doors. We just put down the sand yesterday. We are pouring a 4in slab.
    The mexican that didnt get away
    Jan 2006
    DAAAnngerrr Zone!
    Quote Originally Posted by Reckless View Post
    atleast you left him a breathin tube. What are yall usin for compaction on the sand?
    'Cause if she don't,
    Dec 2005
    BFE, Tejas
    Skid steer bucket and a little bit of water
    Jan 2006
    DAAAnngerrr Zone!
    If your skinny ass leaves more than a small imprint in the sand when walkin on it, get a good load of dirt in the bucket and just use the skidsteer wheels to 'wheel roll' it. Looks like yall are doing a good job, what is the pipes for? Sink or crapper?
    Dec 2005
    BFE, Tejas
    both. the poles are 2 7/8 oilfield pipe
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Me crackum 4" slab in my shop.
    Brazos County
    did you or did the subgrade cause it?
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
    Aug 2004
    Corpus Christi
    Dunno, building is old as fawk.
    Sep 2004
    4" is too thin if you are going to park/put anything heavy on it
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    Dec 2005
    BFE, Tejas
    Quote Originally Posted by RCook527 View Post
    Thats what i told the step parental but hes a joo. I said 6in.
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    Quote Originally Posted by Seth View Post
    he dropped a 6.2l
    are you not putting any beams in there? it would be a good idea on where you plan to park things at the very least along w/ a perimeter beam. it would make the slab act more monolithic...generally you do it every 8' both directions. I would do at least 1' X1' beams and put heavier bar in these beams. if you are really ambitous you can line the bottom w/ plastic. I think it acts as a vapor barrier and allows the concrete to cure a little slower and make it stronger.
    Jerry? I'm surprised you haven't chimed in. Aren't you mister cement in stinky town?
    Jan 2006
    DAAAnngerrr Zone!
    4" can be done if the correct rebar and cement mix is used. If you plan on pulling anything heavier than a pick up in there, then make sure the rebar is on 8" centers and you get at high psi mix.
    Dec 2002
    Austin, TX
    Concrete's espensive. As long as their soil is decent, a little crack isn't going to harm anyone.
    Then again, I've never seen a 4" slab and would second the grade beam idea, but since you've already laid down the sub-grade, that probably ain't going to happen.
  15. #15
    Oct 2002
    Poth, Tx
    I've seen plenty of buildings with 4" thick flatwork as slabs. Yea it'll probably crack, but its just a crack. Costs a whole lot less than a regular slab. A normal concrete foundation would cost twice what they're gonna spend on the building.
