Pretty piomp!
Pretty piomp!
Tite, gonna whack the flange flat on a mill?
no, I got the flange from some site that sold it and pipe fittings to make your own ghetto turbo manifold. Its probably twice as thick as it should be so I'll take my chances with warpage.
where did you get the parts for that?
most of it from mouser, but they had a stupid high minimum order for the relay terminals, they came from waytek
going to try some aluminum next week, but I think I've got the shifter figured out
Built a cabinet for it too?
You amaze me Flemboni. That's crazy stuff.
how to remove gudgeon pins
make jig on cnc router
use press
sweet
That's what I did at cooks when I got bored. Except I could break the pistons so normally ended up breaking them off with a hammer and pressing the pins out of the rod. I would hate to do more than one with your rig, the rod would move down and make it press crooked and break the piston. You need a wall on the rear to support the rod.
pin presses into the piston, not the rod
