Page 13 of 16 FirstFirst ... 3 9 10 11 12 13 14 15 16 LastLast
Results 181 to 195 of 226
Thread: Sunbeam
  1. #181
    Jun 2005
    Krazy Krosby
    Just so you know, you voided your warranty by breaking that seal.
    How does this work? When you push the toggle, does it switch the speaker output so it is connected direct to your headphone jack? Does that mean the only thing powering the speakers is the phone? Or does the signal still go through the radios's amplifiers and you can control sound level by adjusting the radio?
    -Karl
    1965 Chevelle
    1975 Corvette
  2. #182
    It still goes through the amplifier and the trebel bass knob.
    I'll post a picture once the circuit is done, the main part is a nte4066 chip that you can get at Frys and probably radio shack. Its basically an electronic relay that lets you select analog sources.
    There was a blue wire in the radio that went to the volume knob. The volume knob is just a potentiometer so using a voltmeter I identified which one of the 3 legs was the low end of the carbon track, cut it, and the potentiometer side of the wire became the input line while the other half became the AM output line.
  3. #183
    Sep 2006
    DFW
    Sounds cool!
  4. #184
    Chief
    Sep 2008
    Impressive Flem
    2010 VW Jetta - DD, 5 Banger, 5 Speed, 1000 Watts of sound!!
    1979 Ford Bronco Custom - 400/T18/205.. 35" SSRs, 4" lift, Rancho 5000s, 200 watts of sound!!
  5. #185
    rebuilt the tachometer with modern electronics, repainted needle with model car paint "flourescent red" from hobby lobby, obtained correct series 5 speedometer and cleaned it up.
  6. #186
    Hazaa Fredo's Avatar
    Kickass Flem! You end up getting the carbs rebuilt yet?
  7. #187
    yeah, got them on there tonight. I rebuilt them a week ago just haven't built up the patience until now to tackle those 2 bolts that require a crowsfoot. Big difference in the way it starts, the corrected timing helped too.
  8. #188
    I told you to take the BMF-478G Sunbeam Mounting Bolt Tightening Tool with you.
  9. #189
    Oct 2004
    Headed back to the Big D
    you keep a small child locked in the shop?
  10. #190
    it almost has power brakes
  11. #191
    Respek TdmayfieldIV's Avatar
    Sep 2009
    who needs power brakes?
  12. #192
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Needs more soda!
  13. #193
    needs more air filter. It was missing and the chamber was full of corn mash
  14. #194
  15. #195
    Sep 2009
    only $175, perfect finishing touch for the sunbeam.
    F*ck off cj.
