Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Thread: Shop Air
    Aug 2002
    Shop Air
    There's a lot of BS elsewhere about this but what's a simple, cost effective way to run air around a shop?
    I am thinking of running black iron pipe from one side of a garage to the other along the ceiling, with a little dip in the tube and drain as a moisture catcher just before each outlet. Short piece of soft line connects the compressor to the system. Anything wrong with this?
    Somebody had an elaborate setup posted up in the ultimate shop thread, let me find it.
    I think if you can just keep a small slope in the pipe it will go a long ways to keeping it a bit drier and just have a valve at the bottom/end to let the water out.
    http://www.1969supersport.com/draw1.html
    like I said, elaborate, but should give you a few ideas. I have started to see a few more pvc setups, I just don't know how long they would last.
    Aug 2002
    that is elaborate! I am thinking more like one of these:
    VW Ninja Jackasic's Avatar
    Jackasicstan
    use PVC instead of iron
    Oct 2002
    Poth, Tx
    PVC has been in my dad's shop since 99.
    Quote Originally Posted by uglyota View Post
    I did that exact setup at my parents house and even with 3 inline filters water still gets through the lines. You need to have some distance between the outlets and compressor.
    Wylie, Tejas
    We used copper, but that was when copper was cheaper, and I think it fell off the back of my brother-in-law's truck as well. We just have an inline filter and an expansion type dryer that is probably older than dad before it goes into the lines. Nothing elaborate or expensive for sure. The tank on the compressor is huge though, and a lot of water gets caught in it, so that probably helps. No considerable moisture in the lines to speak of, but we aren't shooting paint everyday either. We have a reel by the compressor, two small whip hoses on either end of the bench, and another reel by the back door. Much handier than dragging hoses all over the shop. Why do you want to plumb air lines for a single car garage? Doesn't seem like there would be much benefit.
    Aug 2002
    My thought is that in a small area it will be even more important to keep everything straight and not dragging all over the place, so having the air right next to where you're working would help that. I might be able to achieve the same result just with a reel under the workbench at the front of the garage though...and it would cost under $100 to do the two drops with copper.
    Maybe I could put another tank in for expansion/condensation before it enters the system?
    I feel so lame for getting excited about this. Wait till you see my shelving thread!
    . J Cooper's Avatar
    Sep 2002
    Where you stay?
    why not just run the pipe up into the rafters and then attach a real in the middle of the garage
    thats what i was thinking about doing, i have my extention cords set up that way
    Aug 2002
    I kinda thought about that but I think then you would always have the hoses dragging over paint (at least in a 1-car, in the middle of a 2-car it would probably be ideal), and it doesn't solve the moisture problem (though I may be overthinking this, there's really not much moisture in the air here)
    yeah, I don't think that moisture is going to be a big of a problem as it is here
    Oct 2002
    Poth, Tx
    You think too much.
    Plug hose into compressor.
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    ive got a 60 gallon upright with the hose plugged into the outlet. no water problems at all.
    edit- dang it, thats twice in a row ive agreed with kopecki. whats happening to me?
  15. #15
    Dec 2005
    BFE, Tejas
    When we get ours set up in the big shop, ill try to post pics
