Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Irene's hesitation
  1. #16
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    had a clogged fuel filter on the tahoe once. it did the same thing, neutral or not.
  2. #17
    Apr 2006
    Quote Originally Posted by BMFScout View Post
    Is 2000 older? The motor is a 351W GT40 multiport for those that didn't follow the other thread. I don't know if it has limp mode or not, just seems to be pretty consistent.
    The only motors I know have limp home mode are diesels, the 6.0 and 6.4. I have never seen a windsor with limp home mode.
    Born to Kill
  3. #18
    Jimmy its not the limp mode you are thinking of where the computer abandons controls and goes to an analog system like the TBI computer does. It deals with each sensor individually and will throw a code if there is a problem.
    There is no oil pressure input to the computer. Maybe a kill switch was added, but it is not in the pcm.
    I think it will be very easy to fix once you narrow it down to fuel, spark, or both.
    I'm betting its fuel pump/pressure, coil, or ICM.
  4. #19
    Hazaa Fredo's Avatar
    I'm betting it's the S.L.O.W. cuircut. One of the switches has either become disconnected or failed, because it hangs out at 40psi+ oil pressure and never goes above 170 degrees. Check out this page I read out of the 301 page diagnostic manual on the proboss 351.
  5. #20
    Wylie, Tejas
    That has to be it. Once again, John Cox is worthless. Thanks for the input guys. I'll have Fred report back Thursday night. We have an important business meeting tonight at 1000 Ballpark Way.
    Boats and hoes
  6. #21
    Apr 2004
    Cowtown
    karl gave the only real advice in the whole thread. after that i had nothing to add.
  7. #22
    Registered User
    May 2003
    Htown
    hey jimmy, does this boat require one of those pumps to change the oil. If so I have one sitting at my mom's house if you or anyone else wants it.
    So you loose, I win!
  8. #23
    Apr 2004
    Cowtown
    Quote Originally Posted by Snatch Adams View Post
    if it looks like these, i know jimmy already has a few of them.
  9. #24
    Registered User
    May 2003
    Htown
    Quote Originally Posted by agjohn02 View Post
    cox pumps? I thought those were your bag?
  10. #25
    Apr 2004
    Cowtown
    tell that to the little round hickey on your left thumb
  11. #26
    Wylie, Tejas
    inboards have a hose you can stick through the drain plug which is conveniently located in the middle of the boat. thanks though, I just pump pills much easier.
    Boats and hoes
  12. #27
    Brazos County
    Sounds like you kinda have it narrowed down, with some John Cox Insecurity to boot, but just for grins, can you pull codes off this motor? Do you have a "check engine light?"
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
  13. #28
    Brazos County
    Two things after reading that tech page. 1 - Don't challenge Fred if he tells you he knows something. 2 - Interesting that the comp is an EEC-IV. I guess they kept the system for marine use after they changed the autos.
    Seth Stewart '04
    2000 Suburban DD
    1975 Scout - TBD
  14. #29
    Wylie, Tejas
    probably should have a check engine light but we don't. fred sat out on the meeting tonight to fix the boat. it was the oil pressure sensor. Fred wins again! I tried real hard in my e-search to beat him, but it was futile.
    Boats and hoes
  15. #30
    Yeah, the oil pressure switch was bad. If we would have had the audible alarm hooked to the system, we would have known right off the bat what the problem was. I guess we could find the optional audible alarm and put it on there, because the lesbo ex-con forgot to stea...i mean remove it from the boat that the engine came from. I also adjusted the throttle so it now actually opens WOT. The way it was when we first installed the throttle cable, there was about 3/8's of an inch of the throttle that it wasn't using. Plus, with that vaccuum leak we found, it was probably pulling timing so I'm kind of interested to see what it will be like now.
