Page 184 of 211 FirstFirst ... 84 134 174 180 181 182 183 184 185 186 187 188 194 ... LastLast
Results 2,746 to 2,760 of 3159
Thread: Random Tech Questions
  1. #2746
    Jan 2010
    Does a ls1 have the same bell housing pattern as a vortec 350?
  2. #2747
    Yes.
  3. #2748
    motor mounts are in different locations but you can get adapters cheap or make some.
  4. #2749
    yes and no. An LS1 uses the middle top bolt hole and doesn't use top bolt hole on the passenger side but for all intensive purposes it is the same. Also for an automatic you have to use a spacer to support the front of the torque converter
  5. #2750
    Brazos County
    oh creighton....
  6. #2751
    Quote Originally Posted by Seth View Post
    oh creighton....
    l o l
  7. #2752
    Registered User heathermcc's Avatar
    Oct 2011
    College Station
    Name:  front steering.jpg
    my front steering as it sits now
  8. #2753
    have you had an allignment since the lift? correcting caster, toe etc.... th
  9. #2754
  10. #2755
    Oct 2011
    College Station
    Quote Originally Posted by colman View Post
    we got it aligned at firestone, caster isnt right yet
  11. #2756
    F*ck off cj.
  12. #2757
    Feb 2011
    Rotors will be being replaced tomorrow. As well as tire balancing. We have seriously checked everything else.
  13. #2758
    is the brake pedal pulsating when you press on it?
    F*ck off cj.
  14. #2759
    Feb 2011
    Honestly hadn't thought about it till about ten mins ago. But it would make sense why it's been being caused worse and worse when you use the brake.
  15. #2760
    Feb 2011
    Plus she was told in August (when the wobble started) that she needed new rotors. I haven't payed any attention to them really but I think Taylor looked at them today
