Page 164 of 211 FirstFirst ... 64 114 154 160 161 162 163 164 165 166 167 168 174 ... LastLast
Results 2,446 to 2,460 of 3159
Thread: Random Tech Questions
  1. #2446
    Hazaa Fredo's Avatar
    Wasn't this in a YJ? Maybe the shifter arm on the case is a different length than a TJ one. Either that, or you're probably going to have to loosen that little adjuster nut on the horribly designed TJ linkage and adjust it for the new case. If that doesn't work, just order a Novak Cable shifter for it.
    http://www.novak-adapt.com/catalog/shifters/sk2xc.htm
    Why do I still know **** about jeeps?!
  2. #2447
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    It is different. I had him send me his linkage. It still doesn't line up.
  3. #2448
    I started to change the diff fluid today, but I can't remember how to get the diff cover back on.
  4. #2449
    bwahaha
  5. #2450
    nice! toyota upgrade?
    i dont speak australian.
    seacrest, you are my hero!
  6. #2451
    Dammit...is that Kunta Kinte?
  7. #2452
    indeed. He came over to borrow the plasma earlier. I'll let him fill in the details.
  8. #2453
    yes, it had to be done
    to keep it on topic, here is some random tech on how to fix a diff cover
    that new thing is .300" thick
  9. #2454
    Ahh. Okay so you just beat the **** out of it. More I-hop curb hopping? I'm disappointed I wanted to see some toyota thirds.
  10. #2455
    got the thirds, just don't have the things that go between them and the wheels.
    thats just random trail damage, clayton this year finished it off
  11. #2456
    on second inspection is that a drill stem pipe cap with the threads cut off?
  12. #2457
    its a weld cap, for pressure vessels or piping or whatever needs to be capped thats 8"
  13. #2458
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    I put a TJ case in my XJ, I had to swap the linkage arm on the case to mine to make it work right, the TJ linkage wanted to make it shift backwards. They have a different angle in the ovaled hole
    Get your wife or someone in the jeep and have her shift the tcase shifter while disconnected from the case and watch which way it goes and then look at the case and figure out which way it needs to go and then put on the right linkage.
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
  14. #2459
    Dec 2007
    Tj linkage went backwards. I used the yj and it goes the right way. Just doesn't have enough throw to go all the way back
  15. #2460
    For the slow-fiddy-fo. JBA shorty headers and y-pipe into single 3" or 3.5" pipe? Flowmaster 70 series muffler with cats removed and simulators for rear O2's. Intake and possible injector upgrayedd in the future.
    I can't find any of the 70 series in a 3.5". I think I can make a 3" work in my application though.
    (oh, and taken you long enough to get around to this ****! )
