I ended up going with the 50 series Flowmaster that has dual 3" inlets and a single 3 1/2" out. Truck sounds awsome now. Now on to the injectors...
Anybody know where to order a custom length chromoly 30 spline rear Dana 60 shaft? Full float with ford outer? Length is 30.25".
Chris check the splines, if it's ford I think it should be 31 spline, but double check before you order. Complete off-road I think had the best prices. They typically sell the cut to fit and you order a shaft that is in a range of 4" or so and you simply measure your shaft and cut off the excess.
Ah, yes flem I jsut went out into the shop to verify and you are correct.
Flange pattern. Thanks guys never had to do this before will give moser a call tomorrow. This is for my dad's rig
Anyone know where I can buy a caliper mounting bracket for a front late 80's early 90's Ford Dana 60? Mine have been "modified"....
man, i had some. I think I gave them to Kolpecky - or maybe Landon
What would one expect to pay to have a camper shell painted?
Anyone ever seen anything about these. . .
http://balancingrockdesign.com/BFF/index.html
They seem legit, but I am skeptical considering that ballistic has been in design of a year and has not come up with anything marketable yet. Opinions?
I've seen two or three other similar ball joints out there that replace the nylon insert with metal, and the people that have them like them. I think Ballistic hasn't completed theirs because they are trying to church them up as a rebuildable joint...that and they have their hands full with providing customer service for all their other parts.
$200 per side? Just use full circle snap rings and the balljoints won't get shoved out anyway.
