Page 69 of 211 FirstFirst ... 19 59 65 66 67 68 69 70 71 72 73 79 119 169 ... LastLast
Results 1,021 to 1,035 of 3159
Thread: Random Tech Questions
  1. #1021
    Hypothetically speaking, lets say one was removing the intake from a Ford 351C and snapped the front passenger bolt off. Lets say this person then expertly hole punched the center of the bolt, drilled it out, removed the remaining threads and was running a tap down the hole to clean it up. Further lets "hypothetically" say the 5/16"-18 tap broke off in the engine block just as this person was finishing.... Then lets say this person created quite a few new cuss words.
    Where would this person be able to buy a tap extractor set like this one from Walton tools or something similar in Houston?
    Luckily, it is a thru hole, anyone ever plasma'd one out. I am thinking, I mean hypothetically this person is thinking of trying that out.
  2. #1022
    I swear, you could **** up a wet dream.
  3. #1023
    In the grand scheme of things, how important is that one bolt really???
  4. #1024
    if it's a thru-hole oil (blow-by)will probably come out it with no bolt
  5. #1025
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    How do you break a tap whilst chasing threads?
    Frick, you better just put him down.
  6. #1026
    if i were the person I would leave the tap in there and leave out one bolt and add some rtv to keep the blowby down
  7. #1027
    JB weld FTW!
  8. #1028
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    This must be a fake situation, because ford never made an efi 351 C. Said person does have 2 351 W efi motors.
  9. #1029
    I would agree with leaving the bolt out, if it was in the center of the manifold. This is the front pasenger bolt. Right where the water passage for thermostat is. I think it is important, unless a 351 likes water in the intake and in the oil.
  10. #1030
    Quote Originally Posted by agjohn02 View Post
    I have no idea, it was the oddest thing. I was spinning it down hand tight. Just the little tap handle, very little force and all of the sudden "crack"
  11. #1031
    Wylie, Tejas
    Any chance of using the welding rod technique? Just zing it to the center of the broken tap, then spin out? Other than that, I've used reverse drill bits with success. I know they may not drill into the tap, but just the spinning in reverse will sometimes back it out. This tap isn't broken flat at all though is it?
  12. #1032
    Dec 2005
    BFE, Tejas
    they make a tool that has 3 rods that go down each side to lock in the broken tap so it can be screwed out
  13. #1033
    Wylie, Tejas
    really? maybe like this one? I wonder if they have them in Houston somewhere?
    http://www.waltontools.com/products/extractr.htm
  14. #1034
    Dallas, TX
    No Jimmy, I think he was thinking of something more like this...
  15. #1035
    Dec 2005
    BFE, Tejas
    those extractors have saved my ass more than once
