Easier to put the rtv on a gasket and then put the gasket in place rather than reach your hand into the engine bay where sometimes you can't even see what you're reaching for. Also in some cases, for alignment of the part. The gasket also helps to keep you from squishing all the rtv right away while you are getting everything in place.
