The craptastic cavalier is leaking gas from the injector again. I replaced the o-rings a couple of months ago. Pretty simple process, but I can't figure out why it's leaking again.
Anyone have any experience with this other than selling the car?
1988 Blazer...RIP
Rtv
I used actual o rings for the application. I bought the fel pro o ring set, so I actually have 3 more that were for the other injectors. I guess I'll just redo it tomorrow.
I can't see RTVing an injector in place, although it did cross my mind.
1988 Blazer...RIP
did you lube the o-rings before install. use vasoline or engine oil.
Just making sure. Never know bout ya some times. Living in the middle class ghetto can mess with your mind. I was making sure that the o-ring didnt roll or tear when you installed it.
Yeah, I don't know... I guess I'll just do it again.
1988 Blazer...RIP
If it rolled or tore on install, wouldn't you think the leak would be instantaneous upon repressurization of the system? You might want to take a good look at the injector body and make sure the injector hasn't cracked and is leaking from there. How many miles are on this car?
Pinche cavalier! You almost burned to the ground tonight! I guess it wasn't your time to meet jesus. We shall meet again tomorrow at 7:00.
1988 Blazer...RIP
Let me expand on Doug's post. I conversed with him on the telephone last night. He was putting RTV on the injectors (I guess). When he went to start it one of the injectors apparently hung open? so much so that it filled the cylinder with fuel. He did not realize this and tried to start said cavalier. The motor stopped spinning due to a hydro-lock condition. He then removed the starter because the hydro-lock had bent the crap out of it.
Thoughts?
-Karl
1965 Chevelle
1975 Corvette
call your insureance, up your fire coverage, and burn the biatch to the ground.
