clutch master cylinder on my bike crapped out. no pressure from the handle at all. bike jumps and dies when you put it in gear. where in town can i get either a rebuild kit and/or the entire setup?
need to get it together before school starts.
-Karl
1965 Chevelle
1975 Corvette
i was bleeding the system from the valve on the slave. i had taken the master and slave apart, cleaned, reassembled, then put it all back together. i was getting zero air coming out from the slave(hence why i was puzzled). soon as i bled the master from the banjo bolt. i got pressure.
