Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Cummins will not start after a fuel filter change
    Jun 2005
    Krazy Krosby
    Last night I was watching some TV, when my neighbor (Rod Ryan) came over and knocked on my door. He needed help because his Dodge 2500 24 valve cummins would not start. I went over and here is what he had done.
    He changed the fuel filter, then went to start his truck, it ran for a few seconds and died. He tried restarting and nothing. He opened the fuel filter housing and found it had no diesel in it. He poured diesel into it. Put the cap back on and tried to start it again. It would not start, not even a pop. This is when he got me.
    I took my fuel pressure gauge over, which has a vent button on it. I put the gauge on the schrader (spelling) after the filter and had him try to crank. No pressure built up at all. I had him crank for like 30 seconds with the vent open, no diesel came out at all.
    I then started looking for fuses, etc... I always thought the Cummins had a manual lift pump on the block and then the injector pump. What I found was a small electric fuel pump just before the filter. The fuse panels and relays were labled with the most generic labels ever (such labels as "Engine" "Ignition FD" "I.O.D." and "Fuel System Relay")
    I then read his owner's manual. It does not clarify what the fuses do. His owners manual did say that after changing a fuel filter, put the truck in the on position and the electric fuel pump will run for 25 seconds. If more air is in the line than this, a manual fuel purge must be performed. It also said to consult the maintenance manual on how to do a manual fuel purge.
    So here are my questions:
    1) How do you perform a manual fuel purge on this truck, I know some vehicles require a certain amount of gas to prime the pump, the truck has 3/4 of a tank, I would think that is enough
    2) What fuse/relay controls the electric lift pump?
    3) Should I see pressure after the lift pump, if so how much?
    4) Any other advice on starting this truck?
    -Karl
    1965 Chevelle
    1975 Corvette
    if the electric fuel pump is working correctly, you should be able to hear it when you turn the key to the on position. if you just barely crank the truck (just trying to turn it over) the pump should run for several seconds, 15-20 maybe. this will fill the filter bowl. next thing you have to do is crack the injectors at the block. im not sure on the 3rd gen trucks(2003+), but i only crack 1, 3, and 5 on my 2nd gen(1998-2002) with a 3/4" wrench (shorty wrench for the last one). then turn the truck over until there is fuel coming out of the injectors. be careful not to burn up the starter doing this. once they have fuel out of them, tighten them back up, and it should start no problem.
    all this is assuming that the fuel pump is working properly.
    dont know on this one. however, as i said above, you should be able to hear the pump come on for a split second when you turn the key on.
    depending on the year i believe. with just the stock lift pump, mine was running about 11-12 at idle. it would build up to about 15 with the crank and the pump run for several seconds.
    there is no need to constantly crank the truck if the filter bowl is not filling up. the injection pump may be sucking all the fuel out of it from the constant cranking and you will get nowhere. depending on the year, the lift pumps are known for failure. you can replace it with another factory one from the local parts store, but they are only so good. i replaced mine and added a Holley Blue pusher pump. i know scott added a FASS system to his as well as Robbie. Kopecki will tell you the factory stuff is just fine, but i think his truck is an anomaly since the auto trans has lasted as long as it has.
    Steven W
    02 Dodge 2500
    Registered User
    May 2003
    Htown
    Isnt a manual purge just cranking it while the pushing the schraeder valve to let the air out of the system? Crank till fuel comes out?
    So you loose, I win!
    Quote Originally Posted by Snatch Adams View Post
    not so much...
    i have noticed, when changing fuel filters, if i let the fuel completly drain from the bowl then i have to purge the system all the way to the injectors. if i just drain it enough to get the filter out, it will crank back up on its own.
    Steven W
    02 Dodge 2500
    Jun 2005
    Krazy Krosby
    Any idea where the fuel pump fuse and relay are? I would like to check those before I take the pump off.
    -Karl
    1965 Chevelle
    1975 Corvette
    Jun 2005
    Krazy Krosby
    Also, is it possible that the fuel pump was broke before the filter change and the injector pump was just sucking through the pump?
    -Karl
    1965 Chevelle
    1975 Corvette
    i will do some digging. what year is the truck?
    absolutly. this is the number one cause of injection pump failure in the 2nd gens. where there any check engine lights or trouble codes?
    Steven W
    02 Dodge 2500
    Jun 2005
    Krazy Krosby
    Not sure of the year, it is a 24 valve.
    -Karl
    1965 Chevelle
    1975 Corvette
    Registered Eckert's Avatar
    Nov 2006
    you have narrowed the truck down between 98-07.
    if it is a 03-05, the fuel pump is on the back of the fuel filter housing. which is what i think your saying. mine went out about 6 months ago. its a common problem. dodges' solution was to relocate the pump to the tank. which is a $365 fix. goodluck finding a OEM pump to replace it. if i was your buddy, and had the money, i would just look into buying a aftermarket fuel pump, raptor, airdog, fass, etc. the 3rd gens wont run if the lift pump is bad.
    2nd gens however will. but if the lift pump has been out and the truck has been running solely on the injection pump. there is a good chance he might be forking over $2000 to get this fixed.
    when in doubt, bust out some ether.
    Jun 2005
    Krazy Krosby
    The fuel pump is right behind the fuel filter. The truck is a few years old, I would say in the 98 to 04 range. It is not the newer body style like Jerry's.
    -Karl
    1965 Chevelle
    1975 Corvette
    if it is older then Jerry's body style then it is a 98.5-02.
    there should be a fuel pump relay in the power distribution box under the hood.
    im not sure if this link still works, but if it does, it is the service manual for 2001 dodge. HERE i cant get to it from work so im not sure if it still works.
    if the truck is older (98.5-00) some stuff may be slightly different, but basically the same.
    Steven W
    02 Dodge 2500
    Quote Originally Posted by LikeNothingElse View Post
    The radio station DJ Rod Ryan??
    1988 Blazer...RIP
    Apr 2006
    Quote Originally Posted by Eckert View Post
    Try that first,
    Born to Kill
    Dec 2005
    BFE, Tejas
    your suppost to cycle the iginition several times for 5-10 seconds, itll purge then
  15. #15
    Quote Originally Posted by Reckless View Post
    this does not mean to crank on it for 5-10 seconds. all you have to do is turn the engine over and the pump (if its working correctly) will run for an extended period.
    Steven W
    02 Dodge 2500
