Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: Diff or T-case? Need help
Hybrid View
    I got the new bearings/balljoints etc. all put back on Bronco, both sides. Now when I get in it, it runs fine in 2wd, but when I shift to 4HI, and try and pull forward or back up, it will move a couple inches and then bind up and stop. I can give it gas and it does not want to go anywhere. I could make it move, but fear breaking something. I had neighbor get in and I watched the front shaft. WHen it was moving forward or reverse, the shaft stopped spinning a couple times, then started spinning again.
    When I pulled the diff cover, there was no metal or anything in the mix and everythign looked fine. I am thinking t-case. I have NEVER after 10 years of wheeling this ****box ever touched it. I might have changed the fluid once. Its a BW1356.
    I was towed back to camp at Shiloh when the starter failed and had the trans in neutral, but probably still had the t-case in 4lo. Could that done something.
    My day has been ****ty. I got and installed 2 new bad upper balljoints from Advance. You have you remove the lower to remove and install the upper. If I never have to do balljoints in a 60 again it will be too soon. I also broke the nipple off of the inner locknut and the heater core decided that now would be a great time to start leaking.
    Greg picks it up Tuesday to build the bumpers, so I won't get it back till right before Clayton.
    So you would be moving foward and the shaft would stop spinning. Was this while you were still moving or would the whole truck stop?
    Does your bronco's driveshafts have the double U-joint things (big biol test brain not workinh) by the t-case? I once had the inner piece brake, it would rotate fine but under load it would bind.
    While the truck was moving, the driveshaft would stop and start spinning. It has a double cardaan joint on the back, but just the regular yoke on the front.
    Quote Originally Posted by JBrown89 View Post
    Ok so the front screwin up while the back is driving the truck. I would guess you got a ****ed t-case being that you just tore into the diff.
    Registered
    Dec 2007
    take the drive shaft off and try moving it with the hubs unlocked, if it still binds its the trans
    I am going to pull the front shaft tonight and see what it does. I am guessing that it will not change anything. My options are to wait till I get it back in a couple weeks, buy a rebuilt kit for the 1356 and tear into it days before Clayton.....or buy a used one off Craigslist (seen them for $100-350) and rebuild it and just swap it in once I get it back (less stressful timewise this way, but not as cheap)...or call Stak and throw more shiney parts at this turd.
    I have a 1356 out of a one ton I would let go really cheap. It has the slip yoke though.
    I bet I could make it work. I will let you know.
    I was wrong. Its the diff. Removed the shaft and can not move the axle yoke by hand. moves fine in 4hi/lo without a shaft. I really hope I dont need new gears and detroit. I guess I take it to J&P when I get it back.
    Thats fine, I sold one once for like 150 and the dude was wanting to put it in a bronco. I told him twice it wouldn't work but he disagreed.
    Let me get this straight. When you have it in 4wd, it moves because it powers through what ever is binding in the dif? I take it you tried to turn it with the wheels off the ground or the hubs unlocked, correct? I figure you know plenty to have checked it out properly, but the reason I am asking is someone may come along later and read this and want the clarification then.
    Once I read it for the second time, it makes sense. Now, get this biatch ready so we can drin...er, wheel up in Clayton.
    binding ujoints in the axles and the hubs didnt' completely unlock?
    I never completely trusted that spring in there.
    Registered User junior88mj's Avatar
    Nov 2003
    Lake Bryan
    did you happen to replace or pack the wheel bearings if posibliy removed the spindle and did not get it seated or the bearing seated it will pull the axle shafts out a little and they will bind when the hub are locked in
    junior burrell || 88 mj & 77 j-10->soon to be diesel & 79 amx & 68 javelin || amc rules !!!!!!!!
  15. #15
    it was the diff, he had a siezed pinion bearing I believe
