unsure of the ratio or the spline on the axles, one side is missing the drum and brake hardware. 40$ or just make an offer
is it a big bearing carrier?
how do you tell, it is at my house right now
i don't know, google and search
pick me pick me I know. . . .
I don't care about the housing ends, the carrier is all I care about
stock carriers are all the same, only aftermarkets have the larger bearings. And there's several different types of housing ends.
So it's complete except for brakes on one side? Where is it?
BDR
it is also missing the yoke but it does come with a rim and ****ty tire bolted to it. it is in my driveway in bryan
yea its at colmans along with all the other random crap i have
dont realy have a use for one i can use one at work whenever i need to. i prob can hold it for a bit if you need me too.
that pic doesn't show anything except the difference in a disk brake housing or not, meaning the backing plates use 3/8's or 7/16" ,smaller meaning disk. the outer bearings are all the same size ,set 20 timken, but there are different variations of the bearing design(meaning some are sealed, some are not, some are tapered, some are regular roller) big bearing or small bearing means the carrier bearing, 3.125 is factory(up to 31 or 33 spline) 3.25 is what most aftermarket cases are so you can fit a 35 spline shaft
btw the race is stuck in the housing on the right that is why it looks smaller
You don't need to hold it for me. If it's still around after new years I may pick it up anyway. Just thought I would trade something I don't need for something I don't need less.
BDR
