Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Thread: ATV Gas Tank Repair
Hybrid View
    ATV Gas Tank Repair
    So I purchased my brother's old XR100 back from Jimmy. He told me it had a gas tank leak.
    I took it off tonight and the leak is a rust spot from the bottom seam on the tank. Any ideas on how to repair it? I have 3 thoughts:
    1) Properly flush the tank, i.e. no gas in it, put water in and out several times, run air through it for a day. Then try to lay a bead of weld over the rust hole. I think this would be very hard because the metal is already thin, but add in the rust, makes it way thin
    2) Properly flush the tank like above, make a small patch piece and weld it over like a scab. Advantage here is I might be able to get to better metal, disadvantage is I will create a little pocket in the tank
    3) Some kind of epoxy? any suggestions? JB Weld, Do you guys think it would hold? It would suck to be out somewhere and be stranded cause the tank ruptured, spilled gas on me and the bike, then caught me and the bike on fire....
    Thoughts? Anyone got experience with this?
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    they make a gas tank repair epoxy
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
    jeep people fix tj tanks with jb weld. something cracks whenever they do a body lift, I don't remember what it is though.
    acid etch it from the inside. see how bad it is after you rinse. patch like you said. either weld or weld on a patch. by the special tank coating for the inside and out it in there.
    look in eastwood catalog for kit.
    I have done the etch, rinse, coat thing on bikes before. The crappy thing about this bike is the inside of the tank looks good. I am really surprised it rusted out.
    May 2003
    Htown
    it looked like it rusted just a little bit where it the gas sat when on the kickstand.
    So you loose, I win!
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    Didn't you get something for xmas that will fix this?
    Quote Originally Posted by davido View Post
    I don't want to waste my Mighty Putty.
    Dec 2005
    BFE, Tejas
    por 15 has a tank sealer kit
    Quote Originally Posted by Reckless View Post
    this is what i would recommend, It sucks welding on used gas tanks when they are thin.
    After listening to everyone's advice, I decided to do my own thing. We should rename this thread "Well I guess you could do it that way...."
    Have you ever seen some project that was not quite right? Examples: 1) Welding the TTB arms together on a Bronco, 2) Cooking hamburgers on an indoor electric grill, 3) Pretty much anything Kopecki has ever done... These things you see and you step back and think, well I guess it does not boldly break the laws of gravity or space time continuim, so, well I guess you could do it that way....
    Most people I talked to said to weld a patch plate in, but that seemed like a lot of work and the idea of welding around a gas tank seemed horrible.... I cleaned the tank up and found the rust hole was way worse than anyone could have guessed. I did some internet research and saw where some people had used JB Weld <step in and say "Well I guess you could do it that way". The pictures shows what 4 layers of JB Weld and some harvest orange paint will do....
    Next was the muffler. 24 years had rusted this muffler to crap. My dad, Jerry, and Jimmy had all tried to "fix" this with various things like PVC, flashing, worm clamps, screws, and prayer
    Some of you might point out you can buy replacement "silencers" on ebay for about 40 bucks. My experience with this is they are loud and finding one that fit the pipe close enough would be hard. Finding this original part is hard and quite expensive ($400). So I decided to make my own muffler, "Well I guess you could do it that way....."
    My first issue was the existing muffler was 3" in diameter. This is a challenge since 3" pipe is fairly rare (standard sizes are 2" and 4"). However I was in O'reilly's and saw a piece of 3" exhaust pipe for $6. I had a piece of 1-1/4" pipe from a chain link fence and some left over sheet metal.
    I took the 1-1/4" pipe and crossed drilled it with my drill press. I cut 2 end caps from sheet metal and drilled one out for exhaust to flow through and one for the pipe to fit through.
    Previous to welding it out, I put some secret "batting" in it to muffle it some. I cut the original mounting tab off the bike and what was left of the muffler. Then I welded it on. It is not the prettiest thing, by any means.
    I put some gas in the tank, so far no leaks!
    Fired it up, it is no longer loud, sounds pretty close to stock. I did not want to rev it way up since it was like 8:30 when I finished it. I'll throw some paint on it and it should be good.
    So, Well I guess you could do it that way....
    I vote the name be changed to "CRAP-tak-youlur ways to fix a bike that kolpeker never even dreamed of!"
  15. #15
    . J Cooper's Avatar
    Sep 2002
    Where you stay?
    do the brakes next!!
