Page 10 of 11 FirstFirst ... 6 7 8 9 10 11 LastLast
Results 136 to 150 of 151
Thread: The Patrol - Phase II
  1. #136
    Oct 2002
    Poth, Tx
    What's a small pulley? I wouldn't do any accessory underdrive stuff if that's what it is. We spend too much time at idle, keep it spinning fast.
    Why you need a new gas tank? Just worried it isn't big enough?
  2. #137
    H-TOWN
    The small idler pulley is needed to fit the air filter directly onto the throttle body. I don't need a new tank - mine is just modified by droping the stock Toyota pump into it. There is a 5" hole cut out of the top...
    Scott, FTAC '99
    '89 "CJ-7" - Her trail rig
    scott.schubring@williams.com
  3. #138
    Nov 2002
    Tx
    Did I see something on FB about replacing the rear axle and 4 link? Was that just old pics of the high 9 swap?
    BDR
  4. #139
    H-TOWN
    Quote Originally Posted by mudtoy67 View Post
    that's old pics of the high 9 swap. I need to call this Phase III but I don't want to start a new thread...
    Scott, FTAC '99
  5. #140
    Oct 2004
    Headed back to the Big D
    what are you going to do about the electronic throttle body?
  6. #141
    H-TOWN
    I was planning on getting a pedal and using it. What do others prefer? Bad idea? I hate running throttle cables... Wire is so much easier!
    Scott, FTAC '99
  7. #142
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    I have been perfectly happy with the electronic pedal on Pigpen. Cutting and welding the arm will probably take some trial and error though. I would just get a brand new one from the dealership. The one I got from Doggets was only like $10 cheaper than a new one.
  8. #143
    Nov 2002
    Tx
    I guess the only problem I remember was when your battery or alternator took a crap and you couldn't do anything but idle...
    BDR
  9. #144
    H-TOWN
    for the New buggy Patrol build, should I go with a 4.3 Atlas or a 3.8? The tranny is a 4L60E, 39's and 5.13's in the axles
    Scott, FTAC '99
  10. #145
    I'd go 3.8. Do they make something higher than that? I think you'll be shifting to high range a lot with an auto and 5.13s
  11. #146
    H-TOWN
    they make a 3.0 also - man, I need to re-subscribe to these threads or something, I'm not getting the emails...
    Scott, FTAC '99
  12. #147
    Jun 2005
    3.8 if you dont have room for a 4 speed
  13. #148
    H-TOWN
    I ordered the 3.8 ratio
    Scott, FTAC '99
  14. #149
    Oct 2002
    Poth, Tx
    Random idea, can you have the idle speed dropped to 600 rpm or so?
  15. #150
    Jan 2006
    DAAAnngerrr Zone!
    Quote Originally Posted by redcagepatrol View Post
    That's what I have in the back of the 4speed. It is a good ratio break, not too big, not to small.
    'Cause if she don't,
