So the front 44 i got from robbie had the pinion yoke on hand tight. My question is what do i need to do to correct this? If pinion was setup using shims i should just be able to tighen it back down and keep on going? If it used a crush sleeve can i just crush it a little more like 5 in/lbs, or will I need a new crush sleeve and have to reset pinion depth. If all of the above makes your head hurt tell me what i should do to fix this problem. I would like to figure out if i need to pull the gears out or if i can put the axle back together and throw it under the truck this weekend.
